SSR vienna questions.
  • #16
    Ditto. Use something that you can control in longer strokes. You take a chance making the lips look wavy with a dremel... been there, done that. My weapon of choice is a flat file (course, then fine), followed by a typical sanding/polishing.
    • #17
      ok so no dremel :P I have a DA palm sander with all sorts of grit paper.
      • #18
        thanks for everyone who gave advice on my wheels! I pulled out the files and sander. Knocked down the heavy stuff with a file, then went with a 80 to 2000 grit paper. Then took my buffing wheel, drill and mothers and went to town!
        Think they came out great considering how bad the rash was in some spots.
        • #19
          Good work on the polishing. Looks like it matches well. I bet you could be more aggressive and get most of that out though. Just the couple deep ones on the lower right that might not come out.
