is 1/4" gap between wheel and strut enough space?
With a stretched tire on a Mac-strut, knuckle or anything without a bushing, you can run as tight as 3mm safely. If the wheel and closest suspension component can move independently of each other, then you need to test your clearances through your full range of suspension travel.
Your setup should not be an issue for the wheel... the tire on the other hand would depend on fitment.96 Lexus LS400 Airred out on Ordens
88 930 - 500+hp, canned on K18R's "the Porker"
00 V6 Focus - slammed on RS's "the V6Mistake" **SOLD**
by ZX3Tuning, on Flickr
