Triple Step Lip BBS RS offset calculation
  • Triple Step Lip BBS RS offset calculation
    Hey everyone!
    Trying to make some wheels fit on my mk6 jetta
    Theyre BBS RS 023. stock specs are 16x8 +24 5x112
    I'm going to be triple slant lipping them to 18s
    Trying to calculate width, offset, all that
    Stock specs:
    1.5" (38.1mm) lip
    .5" (12.7mm) face
    6" (152.4mm) barrel
    SO with that bringing me to 8 +24 I'm trying to figure out my new specs but it looks like the offset is going to be way low.
    I want to run a 4" lip in the rear, and hopefully 3" in the front, but its looking like thats not possible
    6" barrel, 4" lip, .5" face = 10.5 -8.7 no? that won't fit
    The fronts came out to 2.5" lip .5" face 6.5" barrel for 9.5 +16.7 or 9.5 +29.4 (I think the 16 will fit)
    then 7" barrel, 3" lip, .5" face = 10.5 +16.7, fittable but not what I had hoped for. Am I doing some step in this calculation wrong? Do I need my backpads shaved?
    Is there some way to make a 4" lip fit out back?
    Follow me on instagram: @jaykohens
    The calculations seem to be right or at least very close. You should go by the widths and offsets you want not by lip size. I've never seen the backing pad for that particular rs but chances are you won't be able to take more than 5-7mm safely. If you haven't seen people using that particular lip size and widths for what you want then there's gotta be a reason for it. Either stick with a build you know will work, build the wheels you want and the car around them or find yourself some different faces.
      What widths are u trying to achieve?
      "how do you drive that? Does it have those lifter shocks on it like the low riders?"
      -Faithful Autozone Customer
      Make me insta famous @isupa_shaun
        Im in for this, my RS are on the way...
          I think I will go ahead with 2.5" lips and 6” barrels all the way around. My faces are et17 and et33. I think these might work but I am going to double check before I buy. How did you get the numbers? I think I will just mount my faces and measure for the lip to make sure.
