Reached out to the folks on R3V and was told I should check with the fine folks over here at Stanceworks for additional recommendations. Here's my current situation:
I'm running 17x8 et10, 17x9 et24 BBS RS, centerbore 65mm. They're filled and drilled to 4x100.
This is on an 87 325is, sitting on C3Motorsport coilovers at pretty much the bottom of their regular adjustment. The highest point of my front fender arch is about 24" off the ground. The rear is maybe 23 7/8" off the ground. Note that I will likely be going about 1/2" by removing the adjusters.
Given the offsets above, my first question is whether I should space these wheels out at all to make the most optimal amount of room for rubber (and if so what size front and rear) - or are the wheels already in an OK location as is. If a spacer is recommended, I'd appreciate any suggestions for who could make a custom spacer that adapts a 57mm centerbore to 65mm, in 4x100.
My next question is what size tires should I run. The primary use will be street driving with the occasional autocross.Typically will not have weight in the back but occasionally I will. Ideally I don't want the rims lips to be exposed; I'd prefer that the tires stretch just flush to the lips.
Current tires are 195-40 in the front, 225-35 in the rear. I personally can't stand how much lip is exposed. They're Yokohama s-drives with maybe 85% tread if anyone is interested in them (have two fronts and one rear... the other rear blew out, hence my desire to change my tire situation)
Suggestions greatly appreciated!!
