IŽd like to ask you guys, is problem to fit square 9x17 et20 with 205/40 tyres under e36 coupe, car is lowered on some cheap coilvers, rear is fully down, and about 1,5 cm left in front. Rear fenders are slightly pulled. Thanks
9x17 et20 on e36
Tags: None
thanks a lot, this made my day. I can not wait till sunday
Definitely is going to require a fender roll/pull combined with negative camber and narrower tires. A lot of people run 17x8 et20 style 5s and they require a tiny amount of work to fit (if you are really low) so just keep in mind these will be 1 inch further out.
