I need to buy cone seat lugs for my new wheels. My OEM lug bolts are are ball seat M14x1.5 27MM. The only bolts I am finding don’t come in the same length size as my OEM bolts. I have the option of running lugs that are little shorter (25 MM) or a little longer (30 MM)
Is running bolts that are a little longer/shorter than OEM dangerous? I am not running spacers or anything and the person who made my wheels said the OEM bolt size is fine as long as it’s a cone seat (I am running BBS RS if that information helps).
Here are the lug bolts that I am considering (unless someone has a better suggestion on brand, etc):
25 MM: http://www.brandsport.com/grla-17018sd-20.html
30 MM: http://www.brandsport.com/grla-17019sd-20.html
