How to pull your fenders?
  • How to pull your fenders?
    I picked up a eastwood fender roller and heat gun package the other day to roll/pull my fenders. I know how to roll a fender but I cant seam to find any instructional on how to pull them. So any tips/diy would help. Im assuming after the fender is rolled you adjust the arm to fender distance slightly each time to pull them?
    -Dan
    i made my pulled fenders with a hammer
      i pulled my fronts with my hands muwahahah :P
        That was the original plan. I said "dad, i need to pull my fenders so wheres the baseball bat and hammer?" and then he said no no no and now I have a eastwood fender roller.
        -Dan
          dads are overrated
          i just used a steel hammer and a body angle. worked like a charm.
            ^That came out real nice.
            -Dan
              You have the right idea... a pull is basically when you've completely flattened the fender lip and the exterior appearance changes.
                Put a phonebook between your wheel and the fender while jacked up,then lower the jack and have some friends jump up and down in the trunk. The fronts should be able to be pulled by hand.
                SLAMMED GARAGE
                slammedgarage@hotmail.com
                  Disclaimer:
                  I am rude, opinionated, and sometimes come off as a dick. I am just speaking my mind. If it offends you, PM me. Don't go whine to someone else. I am civil, talk to me, just dont be stupid.
                  and USE THE SEARCH BUTTON
                    the way i do it is you heat the fenders up inside and outside lip, place a bat in between the tire and fender. now lowwer the car down on top of the bat and have someone pull the car foward slowly and back up slowly and at the same time work the bat with hands yanking the handle end down towards the ground. you will have rolled and pulled fenders in no time. easy and cheap. use that heat.
                      ghetto
                        i just kept winding out the guard roller, the i said f#ck this and beat the piss out of them with a hammer haha, front i literally pulled with my hands in the middle of a bust street in the city cos the scrubbing was annoying the hell outta me
                          i used the handle off of my car jack and a heat gun... haha...
                          Stl-Imports.com
                          nightgarage.phpbbnow.com/
                            thats good creativity right there
