Best Paint to Use on Wheels
That was the plan due to low budget hahaOriginally posted by rice4life View PostI too have wondered this.
bump.
How do you plan on painting them, rattle can?
Like our lord and savior says, you can do a surprisingly good job painting something with rattle cans. If you're going for gloss, throw a few layers of clear on there and you can wet-sand it down until it looks like glass.
I did a set of VW 5-spokes a while back with just whatever Rustoleum wheel paint the local VatoZone had in stock, and they actually looked great. Shit, the right front fender on my Mercedes is rattle can from PaintScratch.com, and it looks every bit as glossy as the rest of the car.
Yeah, I'm still sanding right now. Making them really smooth.Originally posted by Jesus Christ View PostA lot of those baller wheels you see all over the internet are rattle canned. If you prep right, it will look good. Won't be as durable but will look good if you're good with paint.
From what I've read on various forums, VHT or Duplicolor are the way to go. I want to get good stuff though, because I want to do it right the first timeOriginally posted by Oh Damn, it's Sam View PostLike our lord and savior says, you can do a surprisingly good job painting something with rattle cans. If you're going for gloss, throw a few layers of clear on there and you can wet-sand it down until it looks like glass.
-Prep to 400 grit
-Use a quality primer. The DuPont aerosols are good
-Sand with 600 grit
-Paint. Custom-mixed or off-the-shelf, just get something quality
-2K aerosol clearcoat. It's a 2 part clear activated with a button on the bottom of the can. I've used SprayMax with good results.
So... prep and quality materials are the key here.
hmm... I'll look into it. Thanks!Originally posted by rice4life View PostYou could try to use a two part urethane clear coat to give the wheel amazing gloss, UV protection, and a bit of rock protection too.
Yeah, I'm gonna paint them pretty soon. I have sanded with 320 grit then 400 grit, Next is primer than I'll sand with 600 grit. Thanks for the advice! I'm going to buy the primer, paint, and clear tomorrow.Originally posted by KyleAnderson View Post-Prep to 400 grit
-Sand with 600 grit
I painted my DS2s with regular Duplicolor paint and then cleared them with Duplicolor wheel clear ... been about 4 years. One did get scuffed a little during a tire dismount, but it is a rattle can job so I never expected it to hold up perfect anyway.
Will painting over powdercoat make a difference if I don't remove it all, and should I fill serious curb rash with bondo?Originally posted by KyleAnderson View Post-Prep to 400 grit
-Sand with 600 grit
Sorry OP, I have questions like you do, and am collecting wheel refurbishing supplies too atm.
𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
@𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
I've heard Duplicolor and VHT are the way to go.Originally posted by slocar View PostI painted my DS2s with regular Duplicolor paint and then cleared them with Duplicolor wheel clear ... been about 4 years. One did get scuffed a little during a tire dismount, but it is a rattle can job so I never expected it to hold up perfect anyway.
It's all good! Pretty much what this thread is for.Originally posted by rice4life View PostWill painting over powdercoat make a difference if I don't remove it all, and should I fill serious curb rash with bondo?
As long as it isn't flaking off, it's fine. Powdercoat is plastic, so it won't cause any reactions with paint.Originally posted by rice4life View PostWill painting over powdercoat make a difference if I don't remove it all, and should I fill serious curb rash with bondo?
Don't use body filler to fill curb rash. It's brittle and likely to break off, especially when mounting a tire. JB Weld will hold up much better.
I personally have done this:
1. Sand wheels down to metal
2. spray a couple coats of etching primer
3. Automotive paint like Dupont and Nason works well and is strong
(Even rattle can works, but idk if it lasts.
4. Do about 3-4 coats
5. Few clear coats if you'd like
6. BAM! Painted wheels
Hope this helps lol
