Whatsup guys having a pretty serious issue with my front tires. my setup is 19x10 -5 up front with 215/35/19 nankang nsIIs just got the car rolling today and im noticing the bead is shifting side to side.(currently running 50psi) when i mounted the tires it had an even perfect stretch. after driving ill notice that the bead will be completely sealed on one side and show roughly 5mm of barrel on the other. and vise versa. i used regular tire lube and a cheetah blaster and things worked out relatively well. any ideas? im thinking maybe i need to just run a 225/35.. i dont see why this is happening because my rears i mounted using trans fluid as lube and a cheetah blaster and my rear wheels are 19x11 with a 235/35/19
Instagram@jdjurhuus
