Strut/Brake clearance on Klutch SL1 for E30 BMW
  • Strut/Brake clearance on Klutch SL1 for E30 BMW
    Quick question;
    In regards to Klutch SL1 wheels in 16x8" et18 front / 16x9" et20 rear - has anybody got these on their e30 and do you need spacers to clear the strut / brakes or are these a direct fit?
    Im mainly concerned with the front, rear wont be an issue as im running 16x10 at the moment, same offset. Ive had 16x9 +20 in the front and required a 5mm spacer to clear the strut. I've also had a 15x8 +15 on the front and it fit directly on. So this 16x8 +18 is in the middle I guess and I think it shouldnt be a problem but just thought I would get a second opinion.
    Thanks
    You should be fine with 16x8 +18 upfront, I used to run 16x8 +20 and had no issues at all.
