Quick question about bbs rm
I've heard of people doing this. You'll get differing opinions. Deflating the tire and doing the bolts one by one is a possibility though. There are only two risks.
1) Since your RMs are two piece, while replacing a bolt you can cross thread it (unlikely, but possible).
2) The seal fails and once you're done the wheel won't hold air.
I say go for it. The worst that happens is that your tire leaks and you have to reseal them. Every wheel geek should have to do a reseal / clean up once in their life.
That would be a mess and ineffective. The seal is on the interior where the lip meets the center/barrel. If that fails you've got a leak. I think you'll be fine though.Originally posted by MEZURASHII_MOB View PostI was thinking that but also thinking as a remove a bolt before a put another on in maybe squeeze some sealer in bolt hole then put new bolt in?
take every other bolt out. replace those with the new ones, and then take the other ones out thereafter. No issue with doing that at allsigpic
1982 euro porsche 930 turbo
This guy knows.... listen.Originally posted by 1badg35 View Posttake every other bolt out. replace those with the new ones, and then take the other ones out thereafter. No issue with doing that at all
haha thanks nick.
make sure to take the air out of the tire. no reason other than extra precautionsigpic
