I'm looking to buy a new wheel set and I've been offered a very aggressive setup of 10x20 et16 front and 11x20 et30 rear. The rear is clearly no issue since it runs 2mm inner than my current setup.
I'm currently running 8.5" (19") et17 with 10mm spacer and 235/35 tire (front). I've previously run 15mm spacer with 225/35 tire but when I changed it to 235 it was no go. Basically the 10x20" would be running 10mm more out than my current setup, 5mm outer than with the 15mm spacer.
Anyone here done work with E39 fenders, or do you think it's possible to run it without fender mods with 245/30/20 tire or something?
The problem is that the diameter is still 15mm larger with 245/30/20 than it was with the 225/35/19.
I know I'm babbling on and on but it's a science as you all know...
These are simply things that can't be accurately calculated since even the same size tires vary in size. I guess I'm waiting someone to approve my plans so I have someone to blame
