BBS RSII 2 piece questions, have leaks...
  • BBS RSII 2 piece questions, have leaks...
    so i have a set of bbs rsII wheels. (rs 714) they have the special air valves as a wheel bolt holding the center to the barrel.
    pics from google. not mine. same wheels different offset.
    one wheel leaks like 10lbs an hour. did the soapy water test and found my leak to be coming from between the center and the barrel, , the valve bolt seals but it must not be sealing angst the barrel, and air is leaking out against the center finding its way out against the lip about a inch or so from the valve bolt.
    so i need to tear down these wheels paint them and stop the leaks correctly. but RSII's are apparently not the most common wheel and finding rebuild information isnt proving to be to easy, i was going to call bbs tomorrow and see where that gets me but i figured someone here might have some incite.
    Check the tire-wheel forum of bimmerforums. I remember a thread where someone said they found a replacement.
