Hi mates, the title is pretty much what i am asking for, is there a difference between 16" and 17" OZ Futura centers with 35 holes? Thanks.
Is there a difference between 16" and 17" OZ Futura centers with 35 holes?
Come on, don't be a retard. Read the question that he is/was asking. He's asking if the CENTERS are different between the 16" version and 17" version.Originally posted by scweet14 View Postobviously. ones an inch bigger
For your information some BBS RS share the same CENTER between 16" and 17" versions. Even the 18" RS "the holy grail" uses the 17" Center.
Lowrider, found out the answer to his question and even posted it here, then you come along a post that douchebag comment. Not cool man.-
Instagram@jdjurhuus
Stretchsaurus and Pokemon.
I've been looking for 16" futura faces for a while.
Do you mind sharing the metric diameter of the smaller 16" futura face? Interested in knowing if it'll work for what I want to do with itsigpic
1982 euro porsche 930 turbo
Thank you much buddy!Originally posted by Zic View PostCome on, don't be a retard. Read the question that he is/was asking. He's asking if the CENTERS are different between the 16" version and 17" version.
I am currently on vacation, but as soon as i go back home i will measure them for you.Originally posted by 1badg35 View PostI've been looking for 16" futura faces for a while.
'84 e30 320i m20b20 zobelbraun metallic
'00 e46 323Ci m52b25 topasblau metallic
'10 e92 320cd n47d20c carbonschwartz metallic
I appreciate itsigpic
I am back, just measured both centers, i would say that the diameter of the 16" center is 33.5cm, and the diameter of the 17" is 36.5cm. (have in mind that i am measuring the diameter of the mounting surface - between the holes/bolts, from the center to one of the bolts x2, refer to the picture)Originally posted by 1badg35 View PostI've been looking for 16" futura faces for a while.
lmk if i can help with anything else
Cheers
Ivan
thanks ivan. hugely helpfulsigpic
