Originally posted by LukeTheGreat
									View Post
++**"Help me identify this wheel!" Thread.**++
	This is a sticky topic.
 Really need help identifying these wheels, 5x114 fitment, 15x6.5j and has "made in japan" stamped on the back, looks like RH Toplines or weds farmas but it doesnt have the holes in between the lug holes
 I only have screenshots of the wheels as they are advertised online and cannot take photos myself, the only identifying mark says "EX545-1" but doesnt show any relevant results when googled
 Any help would be great!
 Any ideas on these? Measurements are:
 16x9 -3 fronts
 17x12 +6 rears
 5x114.3
 Centerbore on the car I put them on is 66.1mm, and the wheel's centerbore was at least a few mm's bigger all the way around, though I didn't think to take a real measurement.
 They're 3 piece, 20 bolt (hex head, PO said they're the original). They apparently came off a car from some local race/speed shop. The one in the pic was painted by the PO.
 No markings on them what so ever from what I can find, though I haven't pulled them apart yet.
 [IMG][/IMG]Last edited by jayjaypea; 08-21-2015, 10:52 AM.
 Thanks, let's try it this way...
 16x9 -3 fronts
 17x12 +6 rears
 5x114.3
 Looks like custom build, maybe using Centerline faces.
 Yea, PO said a similar thing, maybe that's just what it is then.
 Does anyone know some brands/companioes that make lips/barrels with for 20 bolts? I see a lot of 34 hole, 40 hole, etc, but not too many 20. Sorry if this is the wrong place to ask.
 You can order parts without any holes and have them drilled/made to fit. The diameter of the face is also important.Originally posted by jayjaypea View PostYea, PO said a similar thing, maybe that's just what it is then.
 PM me if have further questions. Thanks.
 Look like Keizer wheelsChris Lane - fifteen52 - Join us on Facebook
 chris@fifteen52.com 813.505.7910 - direct : 213.373.1552
 RML | 52 Wheels | KW | ST | B&G | Newing-Alpil | C2 | Air-Lift
 Anyone have info on these??
 I cannot find anything.
 17" 40 hole barrels.
 As far as I can tell they are full 3 piece non welded but the tires have not been removed so I can't confirm.
 Aggressive specs, they fit an s14 240sx really well.
 Supposedly American Racing (center caps) but no other info
 Tags have worn off (of course on the ones with the important info)
  Last edited by Cuttyman9; 08-27-2015, 10:08 AM. Last edited by Cuttyman9; 08-27-2015, 10:08 AM.
 Highly doubt the caps belong to the wheels.
 Clean the top of that label, may be something there.
 Almost always assume the inner to be welded to the outer until you get the tire off.
 Just purchased these for $50 each. Here are the specs on the boxes:
 Model: M106
 17x8
 ET35
 5x112 pattern
 73.1mm center bore
 When I google M106 wheels, all I see is MKW M106 - but these do not look like those at all.
 They look like TSW Thruxtons, but the spot for the valve stem is different. Any information would be appreciated!
 Here's the link - my pictures are too high resolution to attach (sorry!)
