Hey guys, I have been trying to figure out for the last couple days if a set of BBS RC 306 will fit my 2012 Jetta TDI. The wheels are 18x8.5 5x112 et32, the previous owner had them on a 2005 GTI converted to 5x112 and running a 20mm spacer. Any help would be greatly appreciated!
BBS RC 306 on MkVI Jetta? Help.
Your car already has 5x112 as the stock bolt pattern correct? IF so I would think all you would need would be some spacers. What's the stock wheel size and offset?
That should be pretty close to what you need. I'd imagine you'd just need a 10mm spacer or maybe 15mm. But that's just my guess without knowing your stock size specs.
7-10mm spacers would be pretty close to flush, test fit them without spacers with that et and that width it is going be pretty close as is.S4 Avant - Build ThreadOriginally posted by s t a y g o l dand don't trash talk people, that's for hos at the club.
