Tire size help for 8.5 + 9.5 e30 m3
  • Tire size help for 8.5 + 9.5 e30 m3
    I have a set of RS212/197 going on an e30 M3.
    A very common slight stretch setup is 215/40 front and 245/35 rear
    Here's my dilemma.
    245/35/17 has been discontinued for the US by every tire manufacturer except Toyo, but they don't have a matching front.
    I'm thinking a wide 235/40 will work, but I can't find pictures anywhere. Has anyone run 215/40 on an 8.5 front with 235/40 on a 9.5 rear? I think the stretch will be similar front to rear but I want to see some examples.
    Livery Wheel | Facebook | Instagram
    E30 M3 Build Thread
    more like 205 or 215 imo
      235 is not going to have any stretch really
      also check tyrestretch.com
        Yeah I checked there's no 235/40 on a 9.5 listed on tyrestretch.com
        245/35 is a slight stretch. I know it's nothing extreme (and I know this is StanceWorks) but I'm looking for very mild stretch comparable to 245/35.
        This is how the 215/40 and 245/35 setup looks:
        So I want to see 235/40 on a 17x9.5
        E30 M3 Build Thread
          No one is running a 235/40 on a 17x9.5?
          E30 M3 Build Thread
            I'm guessing you didn't try google?
              http://www.driftworks.com/forum/drif...-any-pics.html
              Actually I've been searching google for days. Already seen that one, and probably any other one you'd find in a google search. Looking for better photos, but thanks for cheeky comment.
              Anyone with an e30?
              E30 M3 Build Thread
                If you've seen "that one, and probably any other one you'd find in a google search" (because there are a ton of them) and still can't visualise it, no one can help you.
                I suggest you try this
                Whether you're trying to get your brain back into shape or you just want to keep it as strong as it is now, there are some things you can do to exercise your brain. You can use different strategies to enhance your thinking and word skills,...
                  http://www.wikihow.com/Exercise-Your-Brain
                  There aren't a ton of them actually. You know that since you did the search yourself. The more common size there is 245/35 but you can no longer get them in the states.
                  Thank you for your sage wisdom
                  E30 M3 Build Thread
                    There are a lot and that wasn't any special kind of advice, just basic stuff that is obviously well beyond your abilities, as you continue to prove.
                      Out of my thread peon.
                      Looking for someone with actual experience to post photos of their setup.
                      Thanks in advance
                      E30 M3 Build Thread
                        Ok you're right, I am not qualified to spoon feed retards.
                          Since you are the resident expert and thread cop of the wheel and tire section, why don't you prove your worth?
                          I dare you to find an e30 M3 on Google running the following:
                          front: 215/40/17 8.5 et13
                          rear: 235/40/17 9.5 et13
                          E30 M3 Build Thread
                            LOL
                            Yes because everyone has time to go and find something to your exact needs when tons of info has already been presented. You should be able to figure out measurements or at least visualize the slight variances provided that differentiate between what you can find and what you want. The internet does not have everything you need, about 10 years ago it wasn't uncommon for people to jack up their cars and use measuring devices.
                            Retarded requests like asking the previous member to find measurements to the T of what you need aren't helping your case. You said you searched far and wide already, well then great that's all the great interwebz have to provide. Base you judgement off that and move on to find the answer yourself. Then you can post results for the next time some guy wants the information directly given to him with minimal effort.
                            BOL with your search, that sizing will look great on a e30 m3 IMHO.
                              I bet you still get mummy to tie your laces right?
                              I looked. I found. Go do the same.
