I could use a tire fit check before I order tires for my new wheels, particularly for the fronts.
Rear:
17x10.5" wheel, 315/35R17 drag radials. That's pretty much set in stone, and I can use all the traction I can get. IRS bolts will be ground down and the quarters are already rolled so they will fit just fine.
Front:
17x9" wheel, looking at either a 255/40R17 or 255/45R17 tire. I'm looking at the 255 not so much for stretch but to maximize clearance that I really need. The 45 series is closer in diameter to the rear wheel, but it's slightly larger than the rear diameter, at least based on calculations. ABS errors are not a concern as the ABS system is how shall we say...not functional.
Anyone ever run either of the front combinations? I'm sure it's a slim chance since most prefer to stretch them far more than that.
Any input is helpful.
Rear:
Front:
Instagram@jdjurhuus
