hey all. i own a mitsubishi starion. with the exception of totally custom 3 piece wheels, no one in the aftermarket makes wheels that fit these car's without the need of a wheel spacer, soooo, maybe you guys can help.
just to give you a base measurement, front rim is 8 inch wide with -10mm offset. rears are same wheel, but with a 25mm spacers. so, for the same stance i would need an 8 inch wheel with a -35mm offset in the back. and, as you can see, even with the negative offset, it's not poke.
bolt pattern is 5 x 114.3
12mm bolt holes.
good luck and god speed.
12mm bolt holes.
