So I have been on an ever so long quest for info regarding a certain rim fitment to my car. Nothing new there. Got tired from searching and made a rim simulator.
The rim in question is a 19x9,5 ET40 and whether it will fit my '03 a6 avant without poke. The lowering will be in the areas of Eibach Pro or maybe Sport.
I can't have poke because of the laws here, and I am tired from getting pulled over.
And do mind the car is raised on my widow maker (jack) so it does lean over away from the rim simulator. Meaning, I think, the fender will come over even a little more.
Onwards :
Now, let me just say that this is cut to spec! 19" tall and 9,5" wide. Also 40mm off centre for the ET40. I can not see any problems making this wheel fit,
even got room for some rubber! Is it just this piece of (what ever it is called) that I need to look out for? As I said, I can not see any other contact points, other than tire vs. outer fender ofc.
WTF is this Audi? You call that a caliper?! ..anyways this is the rear.
Thank you for your time, if you have any input please contribute below!
Onwards :
It just seemed too easy
I'll check out those ET's Thanks alot Tomahawk!! Yea there's always something I miss as well, just hoping to get this as right as possible due to long and expensive shipping US. to northern Europe.
