I drive a mk6 gti. If this is in the wrong section let me know. Usually stay in the classifieds.
There is a high possibility I will be trading wheels this weekend however I have some concern with how aggresive these wheels are.
They are autostrada ferrari modena wheels
The specs are
17x9.5 et 15. 205/45
17x10.5 et 15. 225/40
I had a set of rs with the specs
17x9 et33. 215/40
17x10.25 et30. 235/40
I have my rear fenders pulled quite a bit and I sat in the lips of the rs' s in the rear (-2.5 degrees of camber) and they tucked in the front
Is it possible to shave the mounting surface of the new wheels down. Ive looked it up and I cant find any information besides "depends on The wheel" the seller clames that I can shave them down 8mm. Effectively making them et23. Is it also possible to shave down the rotor mounting surface a few mm? That would make the wheels sit at about et26. Which with more camber I should be able to make fit.
Thanks for any advice.
Edit:
Also does anyone know a ratio from camber to offset. Sorry if its a stupid question or doesnt make sense but ill try to explain it.
For example if at 0 degrees you are et 40. If you changed it to -.5 degrees how many mm would that pull in the wheel at the top of the lip on a 17" wheel?
Sent from my SCH-I535 using Tapatalk
The specs are
17x9 et33. 215/40
Edit:
