Hi Folks, I have been offered a set of BBS RS 064, they are 5x112 and 7Jx15H2 ET37.
Will these fit my VR6 Corrado without arch work? Or will they clear the VR6 brakes which is an issue I encountered before.
I know I can get adapters of 15mm and this would change the ET to 22. Or should I look into getting them re-drilled 5x100 and then use spacers to clear the front standard calipers?
