Just got a 318i 1985. Going to throw raceland coils on it(know they aren't that great) Planning to get DR steelies. In the front ,16×8 ET 0 195/40 yokohama S.drives. In the rear 16×10 ET 0 215/40 yokohama S.Drives. Will this setup be fine with just rolling of fenders? Should the rear be 0 or 12 ET? I Don't want to have to run camber. Sorry I don't know alot about fitment. Any recommendations on setup would be appreciated. Thanks!
318i Fitment
remove everything inside the fender lip before you roll the fenders. a wire brush works great, just be sure to protect the metal afterwards.
Go with et12 on the rear. fronts will need some spacers. I personally would go with a 9 et12ish for the front with a 205/40.-
Instagram@jdjurhuus
Stretchsaurus and Pokemon.
So 16x9 ET12 in front. 5mm spacers? And 16x10 ET 12 in rear? This setup will require no camber? Sorry for all these stupid questions. I know their are threads on this but wanted to make one to double check. Also pics of setup you recommended?Originally posted by Zic View Postremove everything inside the fender lip before you roll the fenders. a wire brush works great, just be sure to protect the metal afterwards.
