Bolt holes too narrow
  • Bolt holes too narrow
    Hey guys! Had a quick question to quell my excitement till after finals, I picked up a set of Enkei (92s?) in 4x108 for a 1990 Saab 900, which uses lug bolts, not studs.
    So I have 2 questions, fisrt the bolts are too big to fit in the holes (not the socket, the bolt itself. If I take the time to figure out the bolt difference and use a drill press can I just drill the holes bigger? I am sure it is a big no no in the wheel community but I just don't know.
    Second, saabs use a locating pin which is easy enough to remove, but makes locating the wheel SO easy,so again if I line it up mark it right and use a drill press could I just drill out the hole in the new wheels so I could use the locating pin?
    And because pictures always make thread better!
    Thanks!
    Alex
    Originally posted by JC.
    'Stance' doesn't have to be scraping your car along the floor, that is simply the scene that has caught on. As long as your car looks amazing (in your eyes) while your rolling down the street, that is your own personal perfect stance.
    Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.
    I am pretty sure you are using 14mm diameter lugs on a 12mm shank lug holes. Use a press and a 5/8ths drill bit on a press to open them up (measure them first, I am just relating common experiences on most wheels that face this problem). As for the locating pin I have no experience, but I would advise against drilling a new hole into the wheel.
      Thanks for the response! Those numbers sound right from what I have been reading, I really need to get myself a set of calipers and a new metric measuring tape..
      Also some perspective, got these wheels for stupid cheap and prob don't ever plan on selling them so I am not super worried about 'ruining' the wheels in other peoples, just curious about making them work for me safely.
      And the locating pin is alil smaller than the threads on a 10mm bolt.
