OZ Futura - 2-Piece VS 3-Piece
  • OZ Futura - 2-Piece VS 3-Piece
    Hi all,
    I just took delivery of my 17" x 8.5 ET13 (5 x 112) OZ Futuras. Got them cheap (ish) as they need a refurb so started pulling them apart today.
    However, it would seem they are only 2 piece - the inner barrel and the face seem to be 1 part and the outer lip is 1 part.
    I didnt think you could get 2-piece futura's? Thought they were all 3-piece....this is screwing up my plans.....! Dont want to go man-handling the faces if they're attached or I'll end up damaging them.
    Anyone got any pics of both types so I can compare to mine?
    I looked on google and can only see 3-piece ones?
    So. Do i have 2-piece, or do I need to man-up with the mallett and get them into 3-pieces?!
    thanks for any help.
    Steve
    They all are 3 piece.
    Sometimes it can be really tough to separate the faces from the barrels. I've sometimes just gripped really tight on the faces, and "smashed" everything onto a piece of wood. and before you know it it pops out, takes a couple of good whacks.
    -Instagram@jdjurhuus
    Stretchsaurus and Pokemon.
      Use heat and some hard love and it will come apart
      Bad English = from Norway!
        thanks for the pointers, they seem to be reverse mounted so the face is in palce though the back of the barrel - will get heat/mallet out and have a play later! thanks all.
          Yay! bit of heat and a smack with a mallet and they're apart!
          Thanks Stanceworks!
          These had the faces reverse mounted - if I wanted to, could I put them back together sandwich style to make them a bit wider?
            Thanks Stanceworks!
            You can did it?
            I am in the same situation, but mine rims are in 19"...
