Does anyone know a car that came stock in 5x120 and wheel studs? It'll need to be pretty common also as I'm looking for it in scrapyards. This is going to be for a wheel coffee table project.
Somewhat random question
as far as I know, BMW is the only manufacturer that uses a 5x120 bolt pattern, and they are all hubcentric stock, using wheel lugs. Again this is only based off what I have seen, correct me if i'm wrong. You could always use a stud kit if you want to use the hub as a mounting point for the coffee table- what are your plans for design?
