if im wanting to run any offset other than stock on my e46 sedan are there going to be any fender mods that need done? right now i have a set of breytons i want to run but they are 17x10F +12 17x10R +6. was also thinking about getting a set of oem bbs style 5's or style 19's as these are 17x8 +20 all around. for anyone who has a slammed e46 on offset lower that stock please chime in and enlighten me on what its going to take, also have a fresh set of 225/45/17 laying around that i could use..
fitment options for a e46 sedan
I think the 17x10's all around may be a challenge without some serious fender work.
My car isn't really slammed, but the tops of the tires are even with the fender opening. I have the stock wheels (17x7.5 ET35 front, 17x8.5 ET45 rear) with 12mm spacers in the front and 20mm spacers in the rear with 225/45's all around. To obtain flushness, I'd probably need another 10-12mm in the front, and 12+ mm in the rear.
the 17x10 +6 wont fit unless your doing some fender roll, stretch tires and some camber.
the style 5s or 19 can fit all you need is the right tire, and possibly a fender roll.
Im on style 5's right now with 205/40/17 and all i did was mount the wheels, no fender roll or anything
i even installed a 5mm spacer wich puts me at et15 in the back and i barley have a small rubbing issue under a heavy load or big dip in the road!
ok sweet im just going to do the style 19's. is your car slammed and would you happen to have a pic of your fender gap?Originally posted by e46cruiser View Postthe 17x10 +6 wont fit unless your doing some fender roll, stretch tires and some camber.
yeah my car is slammed lol i have about an inch from the oil pan to the groundOriginally posted by modatrd03 View Postok sweet im just going to do the style 19's. is your car slammed and would you happen to have a pic of your fender gap?
heres a pic of the car.
2012-08-20_18-39-02_796 by VictorGarcia7312, on Flickr
the car has been lowered a bit since then and the rear has come down an inch!
