I'm looking to redrill my OZ Pegasus(es?) from 5x114.3 to 5x112 and don't know where to have it done. Anyone know any place that will do it, preferably in the north east.
Where to Redrill My Wheels
Rotiform does it I know. If you're trying to do it locally, any wheel repair shops/ automotive machine shops are good places to start asking.
Why not wobble bolts for your specific application?Originally posted by electricalbox12 inches of goodness!
You must have not installed them correctly, PCD variation nuts/bolts have been used by thousands of people on various applications with almost never any issues (only I have heard of are from improper installation).Originally posted by drift55 View PostI am running wobble bolts now (sig is an old pic) and they're sketchy! found 7 loose bolts after only 2 weeks after a re-tighten
Be sure to use hub rings to center the wheel correctly, and install them by hand with proper torque pattern/specs. To find that many loose it sounds like you tightened them down without the wheel being flush/centered to the hub and a slight shift could cause the few not properly seated to be loose.
To answer your actual question, many shops can/will do this redrill and will just elongate the hole and press in a steel insert. Call any wheel repair shop, if they don't do it, I am sure they know who can.
Thank youOriginally posted by electricalbox View PostYou must have not installed them correctly, PCD variation nuts/bolts have been used by thousands of people on various applications with almost never any issues (only I have heard of are from improper installation).
Also, I had a shop put the wheels on while i was getting the tires on so they could have been installed incorrectlyIG: @OsakaFlocka
