Hey guys i have a couple post on her about wheel fitment/offset and all those other good things. Anyways i drive a 03 hyundai elantra, i have coils on now and some work cr kai 16x7 et 25. They fit great but... i want to go lower! I have already rolled the fenders and pulled them a little bit. But i need some more camber to go lower. There is no camber kit for the rear and im not to sure how to get more camber without a camber kit. You guys have any suggestions or ideas??? Also when its finally where i want it ill post a thread of pics of the car and you guys can tell me if you like it or what else i can do to it! THANKS GUYS!
Camber question/help.
have you already maxed out your cars alignment adjustments? also known as eccentric bolts? also usually if you lower your car you will also be given a few more degrees of negative cameber.
just google on how to do an alignment for your hyundai so you know where to look for the eccentric bolts. not all cars run "camber kits" or "camber plates"
