I'm trying to order a set of Adaptec adapters, and they've been very helpful. Brad's trying to help me find how thick I need my adapters to be. The problem is I have no idea what offset my wheels are.
I measured the width and the fronts appear to be 7.5s, while the rears appear to be 8.5s. The 7.5s seem to have a little less than 5" backspacing, while the 8.5s are right on the dot at 5" backspacing.
I checked this thread and found the Offset/Backspacing chart very helpful. According to the chart, my 8.5" wheels with 5" backspacing would result in it being ET+6. Did I figure this out correctly, or did I do something wrong somewhere?
However, the fronts are a mystery to me. Here are some pictures, and hopefully someone can help me out.
The 7.5" wheel as measured from bead to bead.
The markings inside the 7.5" wheel. Not very helpful..
Backspacing on the 7.5" wheel.
Here's the 8.5" wheel as measured from bead to bead.
Backspacing on the 8.5" wheel.
I also found this calculator and I put in some mock numbers. I think the rears are accurate, but the fronts seem to be off.
Hope someone can help so I can make it easier on the guys at Adaptec Speedware.
