Hey guys, have an issue here.
I'm in the process of refinishing my LM's and I am also reverse mounting them. I am afraid that these wheels wont balance out right because it looks as thought the faces cannot sit perfectly center within the lip when reverse mounted. The back side of the face sits snug against the lip, where as the front side looks as though it has a smaller diameter, allowing some leeway to be off center when the bolts are tightened down (I have put up a pic to better explain myself).
Any advice? I am thinking about sending the faces to a machine shop and maching the front of the faces down to the same diameter as the back side (the orignal side that is mounted to the lip). I would be losing a few mm of offset this way, but at least it would be safe and everything would balance out correctly.
The wheels are 17x8/9. Anyone ever run into this issue?
The pic below has a line showing the difference of diameter between the back and front side.
Been done hundreds of times with no issue.
