Ok So my wheels finally came home after being built for the last few months. I went out Saturday morning to get my tires mounted thinking it would be a easy thing like always (My last wheels had the same specs and tires sizes and had no issues) but thats was not the case.
I went to 3 different shops.
Using starter fluid and fire - No luck
Using a Cheetah - No luck
Using a bike tube to fill the space - No luck
Old fashion methods of just using air -
we know that did not work.
Every time we used the cheetah it just blew the air right out and did not even try seat. The fire just became a huge fire ball. The nike tube just kept popping out before the tire could even seat. So after trying all day I called it quits as I was tired, pissed out and dying of heat since it was 100 out.
So I figured I would ask for anyone else input on this matter.
The big issue is that these wheels have double drop barrels. I have a huge gap between my tire and wheel. here some pictures to give you an Idea.
Fronts
Rears.
The wheels...
Any help or info would be great. I just want to get these on my car finally.
we know that did not work.Every time we used the cheetah it just blew the air right out and did not even try seat. The fire just became a huge fire ball. The nike tube just kept popping out before the tire could even seat. So after trying all day I called it quits as I was tired, pissed out and dying of heat since it was 100 out.
Fronts
Rears.
The wheels...
Instagram@jdjurhuus
