Those of you following my build thread know I'm going for a very aggressive vert. Well, you can't be aggressive with 8/9"s, so it's time to go big!
I picked up a set of 17x10" all-around et30 Gottis. These should give me a real aggressive stance with small tires for now and allow me to run some real rubber (possibly with bolt-on flares) once I reach my hp goals.
I've test fit them the best I can for now, as I need to open up the centerbore. The rear looks like it should fit nicely, but the front pokes quite a bit and hits the strut.
Any suggestions on what I can do to get these to fit better?
-Fenders-My fenders have a pretty good roll and pull, so not much else I can do there.
-Camber-Currently have -2 & -3 camber. I have BC camber plates, but they are maxed out. The wheel hits the front strut on the inside (probably have to run 10-15mm spacer), so I need the strut to move inward with camber. How can I get more camber in the front and have the strut move in?
-Tires-I'm thinking 215/40 in the front and 215 or 225/40 in the rear. Anyone forsee problems with getting a 215/40 to mount on a 17x10"?
-Front strut clearance-This appears to be my biggest issue, so if anyone has any ideas on helping this (without adding spacers), I'd be very interested to hear.
Thanks!
...and, of course, I wouldn't ask for help without a pic of the wheels.
Thanks!
Instagram@jdjurhuus
