I picked up a set of style 19s a few months ago. 3 lips are already polished, 1 is not. I picked up 400-2000 grit sand paper, polishing kit, and all the goodies. Ive been using beemerbuyer diy and boostedcorrados diy, and have a few simple questions.
Should I sand in small circular motions, or go along with the lip?
I also started to re-do the centers. I was planning on polishing them so I stripped off 80% of the clear. Then, I changed my mind and wanted to paint them dark metallic grey. Since theres some clear coat left on, I was planning on sandblasting them to get all the clearcoat/dark spots out and them sanding them up to 400 grit before applying the primer. Good idea or not? Should I just sand them down a bit then primer and forget about sandblasting them?
