i like where you want to get to. do it.
tires and stretch gods what about 22's
I think it's gonna be a challenge to get there with your current setup man.
I think the offsets you are rolling with are too aggressive to do so, and I think the tires might be too big as well.
If you look at the merc's they are slightly tucking the wheels, whereas you are poking all around. The wheels also look to have a much thinner sidewall, either from stretching or from lower series tires.
It's gonna be hard to do, but it still might be salvageable with some workiiililillillliliil
bar|society
well fitted the wheels yesterday with tires.
front
will need to be 235's for sure or 245s , we are right at the fender sitting flush with lip. Need 3-4mm from rotor and 2-4mm from wheel pad will help ...so worried on the bad though , could run coils for winter. Some rubbing , but 235 is 1inch diameter smaller rolling , that will help.
I didnt notice how to adjust for camber , need to ask around on that.
Pulled front and rear plastic shields to see a bit more.
rear
I'm going to shave the body seam near the muffler to save tires . Other than gaining ET's the rear is fine. If I can gain 5mm or more would be great. 255 is perfect for 10.5. Need 3-4from rotor and 2-4mm from wheel pad will make it dam close to flush without camber adjustment. Also 3-4mm from face of the lip will make things alot better as well.
Coils have about 1.5 left in the front and 1 in the rear with collor in now , so get the 235's , 2nd set rotors -mill them , roll fender, re fit and bottom coilsCrafted Fitment San Fran Sept 3rd Facebook -"Crafted fitment"
Key Fitment - Key West FLFacebook -"Key Fitment"
StanceWars -July 7rd 2012
http://www.stancewars.com
Facebook -Stancewars
WaterWerks June 23 and Sept3rd 2012http://waterwerksnw.com/
Facebook - WaterWerks
Originally posted by Logan View PostThats really cool and kind of funny looking at the same time.Crafted Fitment San Fran Sept 3rd Facebook -"Crafted fitment"
Originally posted by tivs31 View PostI think it's gonna be a challenge to get there with your current setup man.
not dead set on the wheels , but I got them for free and 22's tires are damm cheap .Crafted Fitment San Fran Sept 3rd Facebook -"Crafted fitment"
Little layed out look
well the 235's are on the way for the fronts , I guess I need to order the new brake rotors so i can get them out to be milled down to help the offsets.Crafted Fitment San Fran Sept 3rd Facebook -"Crafted fitment"
Originally posted by herrakani View PostI think you could just roll the fuck out of the rear fenders and lower it to the wheel lip.
Agreed , in the works.Crafted Fitment San Fran Sept 3rd Facebook -"Crafted fitment"
Hell of a job there so far..I'm interested to see the outcome myself once it's all said and done,but had it been me...I would have went wit maybe a 20" in front and 22" in the rear to achieve the stance and look u want from the CLS.....But hell if the wheels were FREE..I would work wit what I have too!! Good luck man.GET THAT KILLA STANCE
