will 18x10" fit on audi a6?
  • will 18x10" fit on audi a6?
    Hi!
    Lookin' at the XXR 521 wheels for my audi a6 avant -99 and was wondering if they would fit? Does I have to pull the fenders alot?
    The wheels is 18x10" square setup, with ET 30 & the tires is 4x 215/35 Nankang NS-2!
    The car is also lowered on Coilovers!
    Will be ordering soon if the would fit so fast answers would be appreciated!
    Regards
    Instagram: tthisischris
    What are the offsets?
    And no, I do not think they will fit at all. My a6 with the factory 16x7 (I think) Do not have too much room to do anything. Granted if you were lower it might make a little more clearance.
    There is an silver avant on bently wheels, I would talk to him about what modifications and final offsets/widths he used.
    C5 A6 / / AMU TT
      Xxr's don't fit Audis because they are cheap rep wheels. Don't even bother
      Sent from my LG-E739 using Tapatalk 2
        Don't be an asshole.. He is free to do what he wants.
        In regards to fitment I have no idea to be honest. I would plug in your numbers here:
        Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
        That should help you a bit.
          They will fit. The B5 guys have been messing with 10s a lot lately.
          Strictly Pleasure/Zero Clearance/Stretch Your Legs
          Alex
            Thx guys! but I've just ordered some 18"x9.5" rota's instead!
              Rotas on a a6 avant.:thumbdown:
              Your car so good luck to ya
              Sent from the tip of my fingers using tapatalk
                So I've been wondering if anyone knows what's the best offset for the "hellaflush" mode?!
                The wheels is 18"x9.5" ET30 square setup, do I need more spacers or is it enough?
                  get them...put tires on...then go from there...best way to figure out whats needs to be flush
                  Insta Mintyhinrichs
                    Best advice I've heard about figuring out if wheels work or not. The only way to know for sure is to try it. If they don't then turn around and sell. At least buying the next wheels you'll know what you have to work with...
                    Flickr
                      18x9.5 et30 should poke a little bit without a spacer. now please dont use the term hellaflush anymore lol
                      If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
                      follow on IG: eurotrashapparel
                        How did you get on mate?
                        car service
