might change my comp's for something new.
Current spec 6" 8j et25 with 10mm spacer. the rears sit perfect with a few mm each side so ideal i want something the same spec
4x108 et15 or above so i can make it et15 with spacer
Any other PCD as lone as its et35 or above as the thinnest hub adaptor i can find is 20mm
Got to suit this and the wheel will be painted white
