Polishing help
  • Polishing help
    Polishing my style 5's, running into a little problem on the mounting lip(?) and need some help. It's sanded down to 2000 wet, but isn't polishing up like the rest of the wheel. I'm using Meguiars Rubbing compound and Mothers mag & aluminum and hand polishing, but when I'm using the polish, it doesn't get as 'black' as the other parts of the lip, and leaves a generally cloudy shine behind. This is from like 2-3 polishes. What am i doing wrong?
    Big picture, sorry.
    More polish and use a power tool of some sorts I use a speed adjustable drill and mothers powerball followed by a cushion pad pretty pleased with the results
    Follow on IG
    amgwheelwhore
    Buy my wheels
    Vintage AME Wheels
    RUF Speedline Wheels
    Buy my cars
    W115 & W123
      I've heard that when polishing (non billet) alluminum, presence or absence of heat makes a difference in the results. I've seen that haziness/milkyness you talked about before, usually when the polishing was done by hand. try using something that will spin fast enough to generate some heat, powerball, or dremel tool, etc. let us know if it made a difference
        +1
          Try Menzerna aluminium polishing stuff(hardwax).. after that use Mothers or autosol to fine finish.
          And finishing polish lower rpm on machine (menzerna has some recommended speeds.)
          LINK TO PDF TO BUY RIGHT COMPOUND
          Project car: MB 190E M50 Turbo build
          Now: MB W211 320cdi
          Ex:MB 190E M50, BMW E39 530d
            Picked up a Mothers' Powercone..It isn't working for me at all. Anyone have any experience with these?
            Oh, and what primer should i be using for the faces? I'm not stripping them down. I have sandable or etching.
              Use a terry cloth pad, and speed and heat are your friend when polishing so crank those drill speeds up! I personally use a power-cone one time over the entire lip, then I hit it with a cloth pad, then repeat the process until mirror shine is achieved. I also use mother mag & aluminum polish. And if that still doesnt work you can always re-sand the wheel again then re-polish.
              Follow on IG
              amgwheelwhore
              Buy my wheels
              Vintage AME Wheels
              Buy my cars
              W115 & W123
                Yeah I'll probably end up sanding again and see what happens. Thanks man.
                  Based on my experiences, (finally finished putting together the new wheels and I am about to seal em up) I found no differences in polish quality between using a buffing wheel on a variable speed drill and hand polishing. The drill was a bit quicker, but I found my self retouching it by hand anyways so I gave up the drill. I was only using mothers mag as well. I would suggest using some real polishing compound as mothers is kind of a "last step polish" type of compound.
