can any wheel be filled/re-drilled? i'm thinking of getting some salad shooters(I KNOW) re-drilled to 4x114.3. possible?
question about redrilling
Originally posted by hek1620 View Postcan any wheel be filled/re-drilled? i'm thinking of getting some salad shooters(I KNOW) re-drilled to 4x114.3. possible?
i cant remember off hand if they do, but if the shooters have a full back pad you should be able to. If it has a 5 bolt back pad I dont think you can drill a 4 bolt pattern into it.
But seeing how cheap shooters cost I say just getting adapters is your best bet as it is most likely cheaper then a fill/redrill/refinish. I know I got my set of shooters for like $80 for all 4
