Great thread
DIY three piece wheel assembly / installation bbs, fikse, ccw, kinesis, etc
This is a sticky topic.
A razor blade and scotch-brite, or a wire wheel attachment on a cordless drill / drill press.@Thatcher
BMW Z3 M coupe
'93 Defender 90 200tdi . '94 Defender 90 300tdi
independentwheel.com
thatcherindustries.com
Can I use any 34 hole barrel/lip to rebuild bmw style 5's/19's from 2-piece to 3-piece wheels?
Great thread...Getting ready to seal my wheels here in the next couple days. Work Equip 05.
This step:
tep 3: Torque down the hardware (you may also choose to torque down the hardware at the very end, this helps with not having a bubble form in the silicone). With Fikse and Kinesis wheels, which use relatively small, M6 hardware, torque spec is 15 ft lbs. Fikse should be torqued to 14 ft lbs. Do not over-torque. With wheels that use larger M8 hardware, torque spec is usually around 18 ft lbs. Torque in a star pattern, rather than just one after another in a row. Do not use a cheap, autozone style torque wrench. Borrow a good torque wrench from a friend if you have to.
If i decide to torque them at the end, do i TQ the bolts after the sealant is completely dry/24 hrs after i lay it or do i do I TQ them before it dries? I appreciate the assistance/guidance.
Never argue with an idiot. He'll drag you down to his level, then beat you with experience.
You should also check out this reference I put together in 2014:
The Official Wheel Build Almanac & Reference Thread
...and my personal build here:
My Road To Futura: OZ Build/Timeline
