I got pretty excited today when I found a set of these for a good price, but some searching tonight has led me to believe that I won't be able to fill and drill these because the center bore is so much bigger. E30 is 57.1mm and these are 72.5. Is there even enough meat there to allow the redrill? I know I would have to run some massive hubcentric rings. Pretty disappointed now...
BBS RS 005/6 onto an E30
any idea on what wheels they are? i need (1) RS211 16x8 et11 to finish off my most recent set. trying to find one but will buy the whole set if the price is rightsigpic
1982 euro porsche 930 turbo
Pretty damn good deal I thought, 5 wheels, 6 centercaps.Wut?
Id assume 4x100. And yours were probably 72.6, im pretty sure its the e39 ( like style 5s) that are ~74mm and cant be redrilledOriginally posted by Rally View PostWhat are you trying to re-drill to? 4x100?
I had mine redrilled to 4x100 and I'm pretty sure the bore was around 72 or something. I don't remember exactly.
Yeah I am trying to go to 4x100. So you are saying that there would be enough metal there for a safe redrill to 4x100?Originally posted by Stephen View PostId assume 4x100. And yours were probably 72.6, im pretty sure its the e39 ( like style 5s) that are ~74mm and cant be redrilledWut?
I looked at it, but i like me some low offsetOriginally posted by Dutchy View Postwhy not 5 lug swap the e30? 318ti rear and e30 m3 front struts. Or if you want to be cheap and half ass, e36 m3 control arms, and e36 struts/spindles with some offset bushings.
You should double check with the shop or whoever, but i believe so. People redrill style 5s commonly, which as i recall are the 72.6mm hub boreOriginally posted by jpod999 View PostYeah I am trying to go to 4x100. So you are saying that there would be enough metal there for a safe redrill to 4x100?
Like Stephen said, check with the shop....they should be able to figure it out for you. I know with my redrill it just required the use of tuner lugs to fit within the wall around the center bore.Originally posted by jpod999 View PostYeah I am trying to go to 4x100. So you are saying that there would be enough metal there for a safe redrill to 4x100?
