Tire pressure on wild strechwalls?!
  • Tire pressure on wild strechwalls?!
    Hellow there, i recently bought a set of Smoor Roadster wheels in 15x8" and they where fitted with brand new Bridgestone Potenza tyres in a 165/50 - R15 size, with mean that the tyres a screaming to the rim edge!
    But my question is, what kind'a pressure will you run on this setup to insure the tyres stay on the wheels? Some say 37 PSI, and others say 50 PSI? Anyone who have som experienze with this type of setup?
    Airride are for pussy's! - Go static or go French!
    Run whatever pressure keeps the bead seated.
    -Matt
    SLAMMED SEDAN CREW #13
      I had problems around 2.5 bar, with flat tire 2 times.. after that i ran 3.5 bar on 225/40/18 on 10" with no problems
      give it some extra juice just to be sure!
      teamdb
        Id say 3bar at least. You could go up to 3.5 i think
        slamburglars.com
          i had 205/40s on a 9.5 and ran 45lbs.
