hi my names chris im 18 years old and got my first project car a 1977 bmw 320i.....i'm wondering if i could get 15" +0 offset 8 inches wide. and 15/by 8/ +10 in the front....any ideas?
e21 fitment?
I run 8.5s and 9s on rolled and pulled fenders. Fronts are ET 0 (about) and rears are ET -12.5. If you rolled your fenders you should be alright. You need to look closely at the front tie rod ends. Going wide up front without a really low offset on a 15 could touch the them.
Those tierods are indeed very annoying.Originally posted by chriskbmx View Postyou think that other half an inch would cause problems with the tierod?
I´m currently running a 14x7 et 10 up front, and they are within 2 mm of touching the tierods.
You should calculate you widths/offsets so that they don't come inward any more than that.
13-14-15" doesn't matter, 16" and up can be some easier, but I don't like the look of those.
15x8 +0 clears the tie rods by mm from memory, i had them on mine without any troubles.
