i need help with this i have some 15x7 ARE mesh wheels that are 25mm off set
so i have a few questions?
1. what size tire would be ideal for this rim?
the car is lower 1 inch the in front and 1.7 inches in the back
2. i test fitted the rim on the front of my car ( i have a svt focus) the brakes caliper touches the inner part of the rim
so would it be better to grind off some the metal off the caliper or run a spacer on the fronts of the wheels
3. if i do run spacers which size spacer should i run?
Instagram@jdjurhuus
or did you just make up your mind now?
