anyone care to explain? I know what rolling and cutting fenders is but how would you pull/flare a fender?
Pulling/flaring fender
very carefullyOriginally posted by 00bmw323 View Posthow would you pull/flare a fender?
lulz
I did I slight pull on my fronts with a regular fender roller, just slowly added more and more pressure to it..
BalleurBuilt•DSDoneform>function"i mean we cant even rock dem shoes if it dont got a comma on the price tag..."
got an answer
Originally posted by boligrafo123Rolling is just flattening the (usually) small lip found where the fender curves into the wheel well, while flaring/pulling involves pushing the fender outwards, which will cause the fenders to "jut out" more. Basically, a roll is needed to gain minimal clearance, while a pull/flare is needed to fit very aggressive offsets, or unusually wide wheel/tire setups.-Jorge-
ehh i just rolled the part that was rubbing which was the center. and it still rubs like crazy
at first i grinded out most of that putty stuff thats inside the fender. then got a bat, lifted the car, stuck the bat in there at an angle, lowered the car. it rolled and flared them a little bit. but not enough for my new setup.
so me and my buddy took a hammer to the inside to flaten them out more.
it helped but i still rubbed.
sooooo.. i got the bat out again. lowered the car on it. until i saw the fender pull out. i did it spot by spot. raising it and moving the bat an inch over every time to keep it even and not wavvy. its super sketchy and dangerous tho. luckily i didnt chip my paint
oh and on my car theres this little bolt that holds the bracket to ur bumper inside the rear fender. that was my first rubbing issue. u might want to grind that down a bit.Last edited by Dubmd; 11-19-2009, 10:26 PM.-Matt
Japanese style rolling
But go to a sports store, grab the cheapest wooden bat you can find, and then raise your car up so the bat will fit in, lower the car a tiny bit so there is pressure on the bat, and use leverage to pull the fender out. Then roll the bat around the fender using the tire as a guide, it shows it in the video, but does it in a crazy as well. I've done it on my audi without issues. The wood is soft enough to let the metal bend without going too far....iiililillillliliil
bar|society
