Hey guys going to be getting tires tomorrow and am still having a hard time deciding on what tires to choose for my style 5's ive been looking at the wheel calculator on willtheyfit.com but still cant decide which would give more clearance for turning up front.
Right now im running an 18x8.5 on a 215/40 up front + 28 offset
Going to be running 17x8 at a +5 offset it will apparently be 15mm farther out than I am right now which im not too sure how it will fit as my fenders are already rolled and im lightly rubbing on my wheels right now, 15mm out is where my fender is
Im hoping that because they are 17's it will still be able to clear due to the smaller diameter??
Anyways the two sizes im stuck between are 215/35 and 205/40 what would you recomend for better turning clearance and do you think they should fit due to them being 17's?
Thanks!
Im hoping that because they are 17's it will still be able to clear due to the smaller diameter?? Anyways the two sizes im stuck between are 215/35 and 205/40 what would you recomend for better turning clearance and do you think they should fit due to them being 17's?
Thanks!
Instagram@jdjurhuus
