Offset question
  • Offset question
    What offset is needed for a 15x8" to stick out the same as a 15x10" et0? I was thinking a 15x8" et-25. Does this sound right?
    changing the width x amount only changes the centerline x/2 which is where offset is measured from. all you ever need to know:
    +1" lip = -12.7mm offset
    +.5" lip = -6.35mm offset
    -.5" lip = +6.35mm offset
    -1" lip = +12.7mm offset
    +1" barrel = +12.7mm offset
    +.5" barrel = +6.35mm offset
    -.5" barrel = -6.35mm offset
    -1" barrel = -12.7mm offset
    et.-25 should be bang on the money.
    -Instagram@jdjurhuus
    Stretchsaurus and Pokemon.
