E36 M3 with Corvette Wheels HELP!!!
  • E36 M3 with Corvette Wheels HELP!!!
    Alright I need some help..
    I just bought 4 spacers for my car (25mm rear, 20mm fronts) and was putting my on C4 Sawblades and everything was fine up until the spacer hubcentric part was too big for the wheels. It would not go in right. Does anyone have any idea what I need to do? Do I need adapters, if so what ones? I am so confused that the hubcentric part of the spacer is too big to fit in the center of the corvette wheel. HELP! I plan on selling my spacers down at H2Oi tomorrow so atleast I'll get my money back -_-
    The corvette wheels are 9.5 all the way around.
    The tires I have on them are 215/45/R17
    If you need any other information, just ask me. I really want these wheels on!
    contact adaptec. they will make the perfect adapter for you.
    tho, people have run those wheels with out adapters, just with spacers. on that hunch i would guess that the center bore of the corvette wheels are larger or as large as the bmw hub.
    check the back of the corvette wheels, and see if there is a hubcentric ring stuck in there if they were run on another model car, its just a round plastic ring.
    try taking a picture of the rear of the wheel. and uploading it here.
    -Instagram@jdjurhuus
    Stretchsaurus and Pokemon.
      researched a little for you. added color to the chart, makes it easier to read.
      seems that you need an adapter, going from pcd 120 center bore 72.5 to pcd 120.6 center bore 70.5 in the thickness you want.
      Tho do your own research, this is based on a google search. measure the hub bore to be sure what size you need.
      CHEVROLET
      Model P.C.D. Offset C/Bore
      Corsica 89>, Beretta 89>, Cavalier 89> 5 x 100 35...40 57.0
      Celebrity 86>89, Lumina 89>93 5 x 115 38 70.0
      Corvette 93>, Camaro 93> 5 x 120.6 38...50 70.5
      *edit; hope this helps man. Best of luck.
        read this thread.
        corvette wheels on bmw
          thank you both for the help. i'll definitely look into it more. i just got back from H2Oi so i was unable to respond. definitely appreciate it. thanks again
