I did some searching and came up with no clear answer...
I have a set of Fabulous Profounds, they are 40 hole barrels.
Can i use Work Barrels, SSR barrels, ETC as long as they are 40 hole? I want to make the rears a bit wider.
I am worried that the hole's entire circumference around the barrel (though 40 total) would not have the same diameter and be off just a little.
How compatible are barrels?
Has anyone tried to use a mix brand barrel setup?
they seem like they would be fairly "universal" in terms of compatibility.
