Time to refresh my LMs since I'm planning on somewhat showing the car this year + they were starting to look a little tired. I had already stripped the anodizing from the lips last year and polished them, never did get them quite where I wanted though. So once again had the tires taken off and since the LMs are 2 piece the centers just pop right out. You can see how discolored the lips got when I washed them down with wheel acid to get all the grime off.
While I was at it figured I'd make a few changes so I picked up a set of red BBS center caps and black chrome bolts from Black Forest Industries. Not cheap for such a subtle change but at the end well worth it.
Now the final result after getting the lips repolished and sealed and wheels put back together. Also, some new stretchy tires should be here in the next few days as I'm going for a pretty aggressive stance this season. Can't wait for the weather to improve to I can throw these on the car and dial in the height and play around with some spacers.
Untitled by egritsenko, on Flickr
